Import Core Body Temperature data
Hi!
I’m curious if there is any way or possible to develop so we can import data from the Core Body Temperature sensor. Currently quite a lot of head units is not capable of recording the data but it can be downloaded from the Core Body Temperature Cloud site. See example file.
Can it be merged to current files within Intervals.icu or can we import it somehow? Maybe a request easily to implement? :slight_smile:
Sincerely
Benjamin
Sample file for August 2022 https://drive.google.com/file/d/1ns6snnkwn1iQJkbPvuB6wOBdKE_fRSjH/view?usp=sharing
Edit: Changed the file because it did not include skin temperature
Merging traces from different files is on the todo list but tricky especially if there isn’t a common reference trace like heart rate. Intervals.icu will pull in core temp from fit files if the head unit writes the data.
Thank you for your reply. The Core files (from the cloud) contains heart rate, maybe it could be used for tracing?
Heart rate will help merge files when that feature is added assuming it is the same in both files.
Looking for some help.
Hi David! Have you hade any chances to look into this? :smiley:
Nope not yet. There has been a big bump in new users recently and I am just trying to keep up with support and bug fixes.
let us know if we can assist in any way. From what I read there are a bunch of programmers on here (me included).
As Hammerhead added support for Core Body Temperature Sensor last week I finally have the data in Intervals! I added a really neat chart to visualise the temperature during the ride. It shows the heat zones in a colourful way that public available for all in Intervals.
Hey all I just got a core temperature sensor but I am struggling to add the data field to intervals.icu when doing a zwift ride.
I am recording the core temperature on a garmin device alongside the zwift ride but how can I then bring that data field into the zwift fit file. Any ideas? Thanks a lot
Currently you can’t. Meaning. It’s either you use your Garmin data file or your zwift data file. There’s no merging of the data.
Hi, could you give me some information about this? How did you import the core data into intervals?
Believe that its just due to Karoo supporting the COre sensor, so that gets integrated into the FIT File
