The iGS630 bike computer from iGPSport is getting more interesting by the day. They have a very long battery live and are adding new features continuously. At that price point i think they will gain traction quickly.
I don’t have one yet but maybe it is interesting to set up a connection with them if they are willing or have already an API in place.
My wife and me shared a Garmin Edge 1030 plus together, though, If bycicling together, only 1 has the data in His Garmin/strava etc Account.
So, i bought an igpsport 630 in November.
I compared igs 630 with Garmin 1030 plus directly against each Other .
The igs 630 is better, more precise speed, GPS, precise height, you know, the percentages going uphill or Downhill, the Garmin 1030 plus is very slow with a lag, the igs 630 Shows percentages going uphill or Downhill nearly instantly, more precise .
So, in Dezember we sold our Garmin 1030 plus on ebay successfully and ordered our 2nd igpsport 630 model!
Hola consulto por que no se sincronizar el igs 630 con Intervasl.
No puedo ve si hace el trabajo como evaluar el trabajo realizado.
Como debo hacer?
Tampoco veo la frecuencia cardiaca.
Здравствуйте!
Я использую iGS630 два месяца. В целом - доволен этим девайсом. В нем реализована загрузка интервальных тренировок из Trainingpeaks через приложение iGPSPORT, и это очень удобно! Попробовал загружать интервальные тренировки из Intervals непосредственным копированием .fit файлов, но IGS630 не может их корректно прочитать - отображаются только временные интервалы без данных по мощности или чсс.
Очень жду решение этой проблемы!
Hello! I have been using iGS630 for two months. In general, I am satisfied with this device. It supports downloading interval workouts from Trainingpeaks via the iGPSPORT app, which is very convenient!
I tried to load interval workouts from Intervals by directly copying .fit files, but IGS630 cannot read them correctly - only time intervals are displayed without power or heart rate data.
I’m looking forward to a solution to this problem!
Я думаю, что нашёл формат, который понимает iGS-630: в том случае, если задаётся мощность, как в абсолютном значении, так и в %FTP или зонах - нужно обязательно указывать " power=1s".
I think I found a format that iGS-630 understands: if power is set, both in absolute value or in %FTP or in zones, you must specify “power=1s”
