Ignore power/pace/HR/... with one click
Right now there is an option “Update settings” to be able to ignore the power/pace/hr/time/velocity an activity.
Would it be possible to add an “ignore all” button next to the options?
This would save so much time. Everytime I want to exclude an activity, I have to manually select all options.
Example where I use it:
I use dual recording for (some of) my indoor rides. Zwift and MyWhoosh don’t store dual sided power data, so I record the same session on a different device.
As it’s a duplicate activity I want to exclude this activity from my totals, but I still want to be able to see the excellent Power Balance and Pedal smoothness graphs.
Why are you ignoring all, time and distance should be sufficient, or can you explain why ignoring the others matters?
As the text next to the settings explains, if you ignore only one value the other can still be included in the totals.
You to ignore power and velocity data to prevent it from showing up in the total time in power zones.
HR to prevent it from showing up in the Time in HR Zones in the Totals.
That’s not excluded if you only set the first value (Time and distance) to ignore.
It‘s excluded. I do it, and it never appears on the total page. If I only select „ignore time and distance“ it is ignoring Totals, and also Time In Zone (HR and power).
