I got a new max heart rate
Is there a way to change max heart rate?
I think I got a new max heart rate yesterday (https://intervals.icu/activities/3196264211) but the readings above my HR trace max have been adjusted. Is there a way to accept these points as real?
Yes. Click the “HR training zones” in /settings and edit the max value on the grid. I have an outstanding todo list item to make this more obvious. You should also tick the “Apply changes to all existing rides” box.
Hello everyone,
is there a function to see the alltime max heart rate? I imagine a information similar to TP peaks wich is scan the workout peaks.
Sorry for my bad english and best regards from Germany.
You can plot max HR on the fitness page (add a custom chart). Be aware that Intervals.icu will clip HR data that is above your configured max. So you might need to bump that up first.
When I created the account, I just put that 240 on max, but afterwards realized it´s “little” over my actual.
I cannot change the max number on the table, all other numbers can be changed.
When I change it and press re-calculate, it goes back to original value.
Heart Rate 240 bpm? This is probably a lot.
Yes, it´s too much. It was the number what was on program when you created the account. But now I cannot get it changed.
Go into settings - HR Training zones and edit the highest value on the line Z7 Anaerobic as per the image David posted above. 2nd post in this thread. Then first save the new value. After that, you should be able to recalculate all activities.
Now I got it, just one change to instructions. You should change all other levels max values also to smaller what the next one is. Otherwise it won’t let you save it and gives error. So the lower levels max should be always lower number. This of course, if the highest value Z7 is actually really high.
Edit, last line added
