When alpha drops so fast it can mean, if there are no intensities to justify it, a fatigue in the autonomic nervous system (ANS).
Very tough intervals 100% Vo2Max to reach 95% HRMAX which is about 2 minutes.
@MedTechCD Just wanted to share w/ you something I was playing with since I got my H10.
Took me a couple of days to figure out how to get the ECG data from the Polar. It wasnât easy esp since I didnât want to utilise Polarâs SDK (Theyâre using a library; RxSwift which I am totally not versed on). Then I had to muddle thru their SDK documentation (somehow Bluetoothâs spec documentation is bad compare to ANT+) and code and do a series of trial and error.(Many many head banging )
So, finally I have something to show for it.
The 2nd Plot truncates the initial ~500 points. Initial goal is just to get the Peak to Valley range so I get good HRV data.
Nice and clean ECG!
Thanks to this thread and my colleague @MedTechCD I learned that âFatmaxxerâ creates ECG records but only for fragments where errors occurred.
Because for several weeks I have been observing my heartâs suspicious behavior (I feel like choking and âstuffingâ with pressure under the lattice at the same time).
âFatmaxxerâ signaled each such episode as âthree artifactsâ or âtwo artifactsâ. I was able to find out the differences between them when I created a graph in Excel based on the ECG records.
For me, âtriple artifactâ means shortening one heartbeat and lengthening the next (as if in a pattern instead of the normal 2 - 2, there was a stroke in the 1 - 3 pattern). âFatmaxxerâ is represented in a pink graph as a downward tilt followed by an upward bounce crossing the midline and back to the middle position from the maximum excursion.
On the other hand, âdouble artifactâ is just the âtop half of the graphâ shoots up sharply and drops to its level (does not go down).
On the EKG, this second episode looks ⌠dramatic: /
From a conversation with a friend it appears that this is ⌠an arrhythmia.
Tomorrow I have an appointment with a cardiologist and, just in case, I also arranged an exercise test (if the cardiologist recommends it).
These are my errors:
(there is a window from âFatmaxxerâ)
BTW - if it werenât for the Polar H10, âFatmaxxerâ, this thread and my inquisitiveness, I would have no idea that something is wrong with my heart.
regards
Artur
Which file is this in when you download them from Fatmaxxer?
@Cary_Blackburn - the question you put to me?
If so, âFatmaxxerâ saves 3 or 4 files.
The first basic one is a file with the annotation âfeaturesâ - it includes parameters such as date / time, HR, rmSSD, SDNN, alphav1, alphav2, artifacts, samples, threshold. Itâs a csv file - so easy to manipulate.
The second basic file is a file with the annotation âRRâ - in addition to the date / time, the âR-Râ parameters are saved.
The third file is with the note âDEBUGâ and the log extension. I do not know what its use is, but I suspect that it is useful for the developer for possible error analysis with the application.
Natoamist, the fourth file is created when there is a so-called âartifactâ, i.e. an irregularity, or with an extension of, for example, a signal drop, loss of communication or medical reasons (heart defect?).
This file has an annotation âECGâ and a csv spread - so easy to process.
It contains the ECG record for ~ 10-13 seconds in the vicinity of the âartifactâ, which allows to assess whether the artifact has a purely technical, communication or medical basis (arrhythmia, excess shocks, etc.).
greetings
Artur
I am using H10 + Edge 530 + AlphaHRV over ANT+
Not many artefacts. Still testing if the value is reasonable.
Many thanks for your excellent and complete reply. Much appreciated.
The ecg file is only recorded when the option is activated in Fatmaxxer. There is one csv file with multiple sections. First section is a 10 sec baseline ecg at start, the following sections are about 10 sec around every detected artifact. You can find a guide to plot them here:
I added âAvg EPOCâ as an interval field. You need to do Action â Reanalyse to see it.
Marco is giving a hard time to HRV while on activities in special on DFA a1
Strong words about DFA
We have been working for some time on personal thresholds, lactate has the same problem, not everyone is 2 mmol or 4mmol, everyone has their personal thresholds, with DFA the same thing happens, another thing is the conflicts of interest that some have, Seiler defends his polarised model that does not work well for everyone, no model is perfect, but we must contribute instead of destroying. DFA has a great future and the research groups will end up bringing it out. I personally am collaborating. Here is an image where you can clearly see the entrance of the first threshold (verified with laboratory test).
@Luisma_Gallego_Soy_P I saw there is a podcast on your work with dfa but it is in Spanish. Is there someplace a summary in English?
I would like to follow-up on what youâre doing because I also believe that there is a future for dfa. It is quite obvious that dfa can be an intensity metric and in a better way then HR alone.
I do however not believe in the fact that Seiler would be driven by a conflict of interest. That doesnât sound like him at all⌠Neither from Marco. I think they just want to warn people that it is not yet the moment to blindly follow the conclusions drawn by very limited research untill now.
I am one of those who think that DFA must be careful and know how it works and how it behaves, the thresholds still need a lot of research, but it is true that there is a change when we are at the first threshold (does not have to be 0.75), I for example after covid my threshold with DFA has moved to 1.19, we are creating a python script to detect these jumps of DFA, like a lactate test to set custom thresholds for each one. Currently working on the basis of alpha values is a very big mistake and if someone is doing it I think they are doing it wrong. DFA can be a great metric to check internal load as well. I donât know if you can add subtitles to the podcast, Iâll check it out.
Pardon my ignorance, but what are Vatios & FR?
Vatios=power and FR=Respiratoria rate
Hi guys Iâm new here,and have been running for 40 odd yrs .The last 10 yrs using Maffetones 180-age and now using fatmaxxer since launch
If accurate Fatmaxxer is saying Iâve been running the start of my long runs too fast(even though low heart rate)and the end of long runs too slow .So if fresh my long runs are now acceleration runs.
One question I would like to know can you just use fatmaxxer to guide you in real time or must you do a ramp test,and if our systems are different depending on fatigue levels etc what is the purpose of the ramp test as on each occasion?
