How to import FTP?
Hello,
I’m new here and I’ve imported lots of cycling activities. I can see that my eFTP is changing over time, but my FTP has remained the same since the beginning (the one I entered at the start). I have an FTP history, but when I change the FTP for an activity, only that one is changed. Do I really have to change my FTP for all 500 of my activities?
OR Is there a way to prioritize the eftp? That way, my activities will be based on the efpt to calculate the load.
Use the Activity List View with the FTP column visible.
Select all activities within a period with stable FTP (should be from - to date), then click Edit - Edit menu to change FTP on all the selected ones in bulk. The column FTP makes it easy to see what’s done and needs to be done.
