How to Guide - ImReady4 app, for HRV guided training
I don’t think I’m connected to Inigo’s folder. I downloaded successive versions to my Mac then uploaded them to MatLab. (I think).
But that fix works.
Robert
I’m not connected to the Inigo’s folder and got the same error this morning. Will try the fix! Thanks
There is no modification for long time. The error is not caused by the script itself.
MATLAB has just released the first main update for this year, R2023a and probably it is related in some way.
I will check it when I come back home today
The change to t.fontname fixed it for me too :+1:
Fixed.
t and s refer to title and subtitle objects. I removed the subtitle in one of the initial versions of the script and forgot to delete this property assigment.
Till today this was not causing errors, neither doing anything, but now current Matlab version seems to deal in a different way empty subtitles.
I have simply removed this line in version 4.41
Thanks. Good to learn something new.
Programming language is above my pay grade. I saw it and changed it, and it worked.
For me show me a update tô 4.41 any different instruction before update!?
As of today I got no written recommendations on imready.
First time that happened.
Tks
I will check if any case is not managed correctly
Can you update and check it now?
It’s got back working again.
Thank you for your support
Just a note - Here in the UK, we’ve just (a few hours ago) switched from GMT to British Summer Time. To get ImReady4 to run I updated the timezone in config_athletes.
Robert
Good point @Dr_Robert_D_Saunders.
Alguien puede ayudarme con estos errores??
Your file structure should look like this (on MATLAB app):
Copy the files as is, and only modify the athlete config file with your name, athlete ID and API-key in line08 of the code. The time zone can be changed too.
Lo veo asi
No encuentro como ponerlo como tu
Use the web browser and the move the files.
It doesn’t work on a mobile device, but does work on a laptop/desktop.
Modifica gracias
No tengo clave api, solo pone (ninguno)
Escribo (none)???
Your API key is found on theSettings page.
Click on view, then copy the API-key.
