How to correct number of swim laps or swim interval distance?
Often/sometimes my Garmin detects the wrong number om swim laps or I forget to change pool length. That leads to wrong interval and activity distance. If I try to reduce the distance of a “corrupt” interval from say 100m to 50m, the duration of that interval automatically reduced. If I then increase the duration, the distance increase again.
Is there a way to change the distance of an interval without changing the duration?
I use this tool to correct my Garmin mistakes.
Thank you! So I assume that it cannot, at this moment, be done within Intervals.icu?
Unfortunately yes. Its quite a bit of work to build a proper swim editor.
Agreed, Nothing better than SWT. Hopefully, it retains ease of use and free use with the change in ownership.
Great new that it isn’t shutting down anymore!
