How to configure integration to receive Strava and Garmin activities without duplication
I was wondering how I should be configuring my integration, I don’t think the way I am doing it now is giving the correct results.
I am trying to pull
Strava : Name, Description, etc.
Garmin: Perceived Effort, Training Effort, Aerobic Effect, Anaerobic Effect , etc.
From either of them heart rate, power etc. normal activity details.
At the moment I have Garmin and Strava both enabled to Download Activities and I have the Keep Strava in Sync option selected. It seems that Strava is used for the name and sometimes the description. Generally the Strava activity seems to be Deleted, if I Undelete it the metrics get doubled.
Any suggestions on how to achieve this?
It should work as you want automatically with the Strava activity deleted and used to update the Garmin one. If you edit the Strava description after download Intervals.icu doesn’t get a notification for the description update from Strava. So unfortunately this cannot be automatically synced.
Thanks, that makes sense. So I need to update the description quickly.
Hmm. strange though, if I Undelete the Strava activity, it shows the activity with the updated description.
https://intervals.icu/activities/8801567762
Here is an example, I definitely edited this after the initial download as I was using it for testing. I was doing some other testing and asked for a manual down of ‘old strava data’ , maybe it got updated in the process.
Yes when you undelete it re-syncs from Strava.
Thanks for the info
