R_M
1
Hi everyone,
I’d like to get an activity CUMULATIVE graph for Heat Stress Score (HSS) during a ride.
The formula is:
HSS = (sec x CT^2) / (3.6 x TCT^2)
where:
HSS = Heat Stress Score
sec = duration in seconds
CT = Core Temp (data stream)
TCT = Threshold Core Temp (user defines it manually)
I’m near zero in Java, cannot understand if it’s feasible or not…
Thank you!
Riccardo
david
2
Here is a script for that:
let TCT = 37.5
let core_temperature = icu.streams.core_temperature
let time = icu.streams.time
for (let i = 0; i < data.length; i++) {
let CT = core_temperature[i]
let secs = time[i]
data[i] = (secs * CT * CT) / (3.6 * TCT * TCT)
R_M
3
It works! @david you’re the absolte best. Wizard!!!
Thank you, I’ll use this script for many other metrics I have in mind, and share it with others!
Ciao
Riccardo
