Healthfit - resting energy not synced?
Just used BreakAway, and the energy fields do sync now. Weirdly enough, I had to add a custom “steps” field. Why is it not using the default/standard field for this? (HealthFit does). Also, BMI was needed to be added but is not filled it seems.
This is why… (have made it use the “default” one in my development branch)
one of 2 things could have happened
  1. there was no standard “steps” field when I added it. Only the Custom Fields
  2. I was drunk
I don’t use BMI and I’m not getting any errors. Can you elaborate?
I selected all parameters, including BMI, in. BreakAway. Hence, had to add it as a field in intervals as wel. The field however is not filled. (I don’t have bmi data, do have weight and length) so that’s probably the culprit. (Thought it (BreakAway/ Apple Health/ Intervals) would calculate it automatically.
One of the differences is that BreakAway doesn’t sync hydration (water consumed) while HealthFit does.
