Graph Not showing AVG or NP
Maybe I am thinking this used to be the case, however when using the graph when looking at my ride I am not seeing avg or np when selecting portions of the ride. Am I mis-remembering this feature?
I should add that I remember being able to select a part of the ride and the power bar would indicate the AVG and NP for that section of the ride.
At the bottom of the page, go to Fields, and then look to see if your desired fields are unchecked.
Check the boxes, and you should see the data show.
Oh duh! i see it now. We are good. Appreciate your help Gerald!
