I still get weight data to my fitness data in intervals.icu. But I have canceled in intervals.icu settings the transfer of weight as I had earlier from Google Fit. And that data was corrupt. It was a fixed data beginning in august this year. Before that it was OK. The problem started when I was forced to change mobile phone. I have tried to disconnect and reconnect Google Fit to intervals.icu but nothing changes. The weight data comes from my Withings scale to Google Fit and that synchronization works. Something strange is going on between Google Fit and intervals.icu.
If Intervals weight is not updated, it will set the last known weight for every day where an activity occurs. That’s because Intervals needs weight for every activity to calculate W/kg.
So my guess is that the last weight from beginning August is being set for every activity after the date that weight sync from Google Fit stopped. It is not ‘corrupt’, it’s just the result of how Intervals works.
Is other wellness data from Google Fit coming in?
Thanks for answering! My data for Body Fat and Blood Pressure in Google Fit are also missing. But my SpO2 and Resting HR data in Google Fit are transferred. I am a Polar user and my other wellness data are usually transferred from Polar Flow without problems.
Are you certain that it’s coming from Google fit and not Polar?
I’m assuming that Polar is feeding Google FIT
I find it hard to be certain about anything at all in Google Fit these days. I have connected Polar Flow to Google Fit and transferring of data for steps, sleep length, heart rate and activities did work earlier but now I have to use Health Sync if I want it to Google Fit. Polar wellness data for Sleep Score, Sleep Quality, Readiness and Respiration I have never seen in Google Fit but I have them in Intervals.icu.
Hey,
I have the same problem. In the past I got intervals to pull my weight from Google Fit (that was taking it from a generic smart scale):
I had to change mobile and Goggle Fit was not active on the new one and thus I have no weight recorded in intervals.
But even once I activated GoogleFit (and verified that weight is now being recorded there), intervals seems unable to pull the data.
