When viewing my intervals.icu workouts in Garmin Connect - I see the text entry that I created but no programmed steps for my workout - screenshots below.
It’s my first time using Intervals.icu so apologies in advance if this is something simple I’m missing.
Punctuation matters here, the fix should be just put a space in next to %
The first couple of lines are OK, but that last line “105%pace” just needs to be “105% pace”
Thanks for the screenshots! I figured it out - I wrote up a few of my observations below between scheduling workouts in garmin connect versus intervals.icu in-case this comes up in the future. (I purposedly left the 2nd step in the interval blank as a rest interval, I don’t like to set a target for my rest intervals)
The functionality is slightly different than the native garmin connect workouts - where with native garmin connect, the calendar events shows a snapshot of a workout in the garmin connect interface (sample screenshot below), whereas intervals.icu creates a workout with the text field in the calendar and an actual workout with the same name and all the steps.
So when I was looking for the workouts on my watch (epix 2) in the calendar widget - I only saw the text field entries - but I now realize the underlying workouts are all on my watch in the workout widget and it seems to load the workout to the calendar a day ahead of time.
Watch pictures for tomorrow (halloween) shows my 6km run as both a calendar entry and a workout, whereas Friday has my shakeout workout only as an all-day calendar entry (I assume by Thursday night this will fill in as a calendar entry and a workout), but in the workout widget for Next 7 Days I can access all the workouts I created in intervals.icu (for the next 7 days).
This implementation of the calendar entry and a workout entry is slightly less clean than native garmin connect creating a duplicate entry - however it doesn’t seem to be a big deal for me.
