@mafelipeb FYI…
The Load / Fitness / Fatigue numbers you’re seeing on intervals.icu web is mainly the calculation/projection using any planned workouts for the week (up to sunday) and it will differ from today’s value (which is what the widget is showing)
Hence I suggested using the FITNESS page to see the value for today.
My ramp on the fitness page for today is 5.3. However the widget shows -2.03, which is what is returned from the API. So the API returns the ramp rate for the week of ‘today’ (-2.03 is the value at the end of Sunday).
Oh man… I didn’t check the API for RampRate. I am using a “snapshot” of the API while I’m working on my own app and i put the difference (for ramp) as due to when my snapshot was taken…
But the Load / Fitness / Fatigue / Form data is based on “today” and not Sunday. That I am fairly sure.
Just a FYI and I sent you a note on the GC IQ Store but when I am in the glance/widget with my Tactix 7 Pro i can swipe down to see the work screen screen but when I try to swipe to get out it won’t go back to the widget screens. I have to use the back button to get out. Only widget that does this but I hope it is an easy-ish fix.
Interesting and just tried it again and does not work. Very odd.
Edit: When I touch into it and go to the next workout screen it will go to that screen via up/down and right to left. When doing left to right to exit it does not do anything.
I am on the current published stable firmware so maybe that is it. When they release the newest one I will see if the behavior changes. With Tactix 7 versions we are not on the beta/alpha as the software is slightly different as it has hunting/fishing and on the ballistics versions has that.
Uninstalled and reinstalled, and now most data showing (Form still null). I may have fat fingered a password when authorizing Intervals on previous install attempt
