Garmin Connect Activity Types
I’m experimenting with Intervals ICU as an alternative to TrainingPeaks.
I push TrainerRoad workouts to Connect, which categorizes them as “Indoor Cycing”. This is not listed as an activity type in the Connect filters so none of my completed TR workouts are importing.
Can this be added as an import filter option, or is there some other workaround for getting these to sync automatically without having to go to Connect every time and change the activity type?
@david, I am also interested in having the Garmin activity type of ‘Indoor Cycling’ added. My indoor rides, that are not on Zwift, as Garmin marks them as ‘Indoor Cycling’ and I filter out a lot of different activity types.
Can you please post a link to one of those. I want to look at the fit file. Intervals.icu currently maps sport=CYCLING sub_sport=INDOOR_CYCLING to VirtualRide. So if you add that to your filters they should come in.
@david thanks for the reply. I will endeavor to get a file unless @Nathan_Berg attaches one first.
Let me know if this link gets you what you need:
I assumed it was related to activity type filters as when i originally synced through connect this was the only type not coming in. Im currently syncing through strava, but there’s some data loss such as power meter ID that gets stripped out so I’d prefer to pull directly from connect.
Unfortunately Garmin doesn’t send activities from non-Garmin devices to Intervals.icu.
Ahh, understood. So if I want to use connect I’ll have to send TR through a 3rd party like dropbox.
@david thanks for the reply and info.
