Hi, I signed up yesterday and connected my Garmin account. But dont know why only the IRL (in real life) activities got imported, and not the ones from the indoor trainer (through Zwift) that are also there. Please let me know how can I import all activities from Garmin without having to do so manually as there are a lot. Thank you! Cheers!
Unfortunately Garmin recently stopped sending 3rd party activities (e.g. from Zwift) to sites like Intervals.icu. You can manually upload them using the “Upload” button on the Calendar page (you can drag and drop lots of files at once) or you can put a bunch into a .zip file and upload that. Or you can connect to Dropbox and put them into a Dropbox folder and add that to Intervals.icu.
I don’t know if it is possible to get Zwift to save its files directly to a Dropbox folder (and hence to Intervals.icu) or not.
This link has some snippets in ref Zwift and Dropbox that might help - not to add to your workload!
Hi David, does this " issue" still exist? I started using intervals.icu. Thank you.
Yes. Garmin has stopped sending 3rd party activities “outwards”. (This is similar to what the other “big guys” are doing)
Best bet is to use Dropbox as an intermediary
Noted. Thanks for quick reply. I will try that.
If you’re on Mac / PC, you can also use “symlinks” (there’s a post here in the forums for a windows solution) to get Zwift to save directly into dropbox (so there’s no need for manual copy/pasting)
Noted. And what if I’m using Sufferfest / Wahoo Systm? Thanks
