FTP estimation via 60mins NP / NP Calculation
I posted this on Bikehub but didn’t realise there was a forum here :wink:
I have questions regarding eFTP and ride FTP (and NP)
Intervals.icu this my 99er ride imported straight from Garmin connect.
The last hour is a 318-320w NP depending where you pick the peak 60mins, so I would assume ride eFTP should be at about that instead of 285w ?
Recently I have done 10 mins intervals with one rep at 371w that bumped my eFTP up to 330w.
My first question is : is there is a specific reason why you give more credit to a one time 10mins effort than a 1 hour NP in terms of FTP Estimate ?
2nd question is there a tool to see our peak 60 mins NP among all rides and within one ride ? Sauce for Strava allows you to see your peak 60mins on each ride that’s pretty cool, but you can’t see a peak for a season or specific period.
Lastly. For the same ride, Sauce on strava gives me a peak 60mins NP at 326w, I wonder why is there about 6w difference base on the same data ? if there are different formula to calculate NP ?
Cheers, once again thanks for the amazing work on intervals.icu :heart:
Thanks. eFTP is calculated using many model power curves derived from real power curves for lots of athletes. So it works with average power for x duration and not normalised power. I don’t think using NP would be a good idea. Someone really good short power and doing many short intervals would get higher NP than someone doing a steady state effort but they might very well have lower FTP.
I have calculating normalised power curves on the todo list. It has come up a few times.
Before I do that I will make it possible to plot “best 5m/20m/60m power etc.” for each activity on the /fitness page. I added the server side code for that a little while ago. Just need to do the UI side of things.
I don’t know why Sauce has different NP. Maybe the 60m best is not the last hour but an hour a bit before that? I don’t know what formula they use but its probably the same. Might be how dropouts are handled?
Don’t wanna troll too much here but is NP of any real interest for training or racing ?
This article explains the difference between NP and AP, specifically on a 1 hour ride and how both quantify how the effort felt.
Thanks but as as a triathlete, I aim for a continuous effort so average power should be close to NP and as a cyclist aiming for long endurance rides, I rely on average/real power to estimate energy consumption.
If I would do a mountainous tri then I would have a look at NP, but IMHO we give a little bit too much importance on NP biaised on the fact that it’s a higher number…
There’s no right or wrong, but rather why both are valid.
That’s why they give an example of a continuous effort vs HIIT training.
