There isn’t yet. It is probably something I should plot on the /power page.
Is it possible to set FTP and CP separately as different values?
My CP is usually 15-25 watts higher than FTP and using my FTP value together with my Wbal does not modell well. Since FTP is lower than CP I can push well below 0 for Wbal.
It can also bee seen in the rather unreasonable values estimated for W’. At 29 700 J and 67 kg i would be at 443 J/kg and that is sort of “off-the-charts” and would be absolute world class.
In fact my umbers are more like an CP of 345-350 and a W’ of 20-21 kJ. I can set W’ but since I can not set CP separate from FTP this model will fail me.
A workaround is to simply set FTP under power settings and within the ride settings as your CP value.
It works for me because I do not really care about the Coggan FTP. We know what CP is physiologically. We don’t know what is FTP.
As for unreasonable values from the model, I think this is where a sanity check comes in. Test the effect of different models, The math is different 2-P to Morton’s. If you have a knowledge of historical values you know to be true, select the model that best approaches those values. Use those numbers.
Yeah, I tend to review power zones in terms of FTP and W’ and matches etc in terms of CP, so I use both. But i can do that in GC anyay, just trying to cram as much as possible over to intervalls as it is a bit more convient.
Unfortunately when I started this I knew nothing about power modelling and the FTP people are good at SEO so thats all you read about when you Google. So Intervals.icu doesn’t have a separately tracked CP field and the workaround is to enter CP for your FTP and W’bal to match.
Hello, Do we use the CP value instead of FTP in order to simulate the use of CP?
