Is there a way to graph a Force-Velocity curve in Intervals.icu similar to what is available in WKO. I know it might not find wide usage but it has become an issue that my coach is now tracking. Thanks for all you do with this wonderful service!
Could you please post a screenshot? Its probably possible to build it as a custom activity chart.
I’m bringing this back to life as I was searching for the same thing. The Force-Velocity curve is a way of tracking peak power at different cadence. It’s often overlayed over a graph comparing force to cadence.
This video does a good job explaining it.
I’d love to be able to do something similar here. A chart comparing max power at various cadence intervals would be helpful.
If you go to your activity power page and at the bottom, on the “Charts” dropdown, search for a chart called “Power vs Cadence” you will find a chart that does this on a per activity basis:
Looks like this for a 2 hour road ride:
Looks like this for a 3 lap match sprint on the track (less data but interesting data when i compare this chart across a range of gear ratios):
