First 10 minutes missing from Intervals.icu
Title says it all really
Id i55559315
Intervals screen shot:
Garmin screen shot:
I started riding and recording on my Garmin 1030 then after 10mins decided to connect my smart trainer to the Garmin. It then started recording speed. Could this be it?
Edit: Intervals is reporting the number of kJ’s correctly for a 30 minute ride
Yes, moving time requires movement or speed.
You can set the activity to ignore velocity and it will include the data regardless.
Actions - Settings - Ignore Velocity data
If you disable GPS on your Garmin, or set the Indoor profile, Intervals will also correctly interpret that.
That’s the strange thing . It was set to Indoor Cycling!
Thanks. That worked
