Error message when changing between pages
Since Monday (i think) i got an error message when changing between pages (activities, fitness, power …) ???
Hmm. It looks like Intervals.icu is getting an error trying to check for new activities with the Garmin API:
{“errorMessage”:"[x]Access to CONNECT_ACTIVITY denied for xxx required ACTIVITY_EXPORT"}"}
Could you please try disconnecting Intervals.icu from Garmin and re-authorising. Tx.
Oh ok thanks… just saw that i had to make a setting separatly directly in garmin connect to allow to send actitivies to intervals.icu… thought it’s be done when i do this in intervals.icu…
Thank you!
So if I understand correctly after you authorised Intervals.icu to access your Garmin data you still had to go back and tick a box?
https://connect.garmin.com/modern/settings/accountInformation
Correct.
First i ticked the box in intervals icu:
but then i got the error message…
Then i ticked the box on connect.garmin.com (this still wasn’t checked)
… and everything was fine!
