Hi there
I have this error.
if I understand correctly the error is due to Suunto API. right?
Thank you
Hi there
I have this error.
Thank you
I get the same message, since this morning.
Seems to be a major problem with the suunto api.
Me too ![]()
Yes they do have a problem. Lots of errors trying to upload workouts and so on. I am trying to get in contact with someone there.
Suunto got back to me and the issue has been resolved. There are many less errors in the Intervals.icu logs now.
I also posted in Suunto Forum. It’s fixed now.
Thank you David!
I got this message for some days. I tried reauthorize without any luck.
I have started seeing this “Error fetching activities from Suunto” error for the past few days. I’ve tried deleting and reestablishing the connection with Sunnto, but still getting the error. I also notice that although I get the error, activities and wellness data does still seem to be coming into intervals.icu ok.
I have started seeing this “Error fetching activities from Suunto” error for the past couple of weeks. I’ve tried deleting and reestablishing the connection with Sunnto, but still getting the error. I also notice that although I get the error, activities and wellness data does still seem to be coming into intervals.icu ok.
If I understand correctly, your activities still come through. Could be “only” a rate limiting error or so.
