I live and train at a high elevation, and have an altitude adjustment for power on my charts.
However, when I ride on rouvy, it will list the virtual elevation, and kind of messes up my power interpretations (ie it will say I am riding at 5000’ instead of the real 8000’).
Any way of eliminating this virtual elevation/altitude?
You could separate virtual ride and rides on the settings page. The customising of the activity page is saved per configured activity type, so you have separate analyses and views for your outdoor and your virtual rides.
If you are the offset is fixed e.g always 3000m difference, could you create a Rouvy altitude field that is altitude + 3000 perhaps using a Formula method? Then your indoor rides use this Rouvy Altitude instead of Altitude? If also using more than just Rouvy & it matches Rouvy then it should be OK. If different platforms have different iniital atltides then it might not work. Then it would be better if Intervalscould have a Fix Data adjustment with scale & offset similar to already exists for power, HR etc. One to ask the moderators about e.g. @R2Tom or @MedTechCD perhaps.
