5 min is the default for the eFTP minimum duration calculation. It might be a bit aggressive, but is based on power curve data. You can increase it (and many people do) to something higher like 8 min to get better calculations for the type of rides you do.
Hmm. The ramp test one has sorted itself out: FTP +11 to 242w from 6m30s at 287w
The first one has actually used a much shorter duration (10m or less) to give you a new eFTP not the time reported in the note. I will have a look and see if I can figure out why.
