Is it possible to estimate FTP/CP based on best efforts longer than 30 mins? At the moment you can change the minimum duration for estimating FTP/CP but not the maximum
(I seriously hate doing max efforts between 6-90 minutes)
Change the minimum time to 1800 sec (30 min)
But that doesnât use your best performances >30 mins
What it does is that it will discard best efforts shorter then 30min. But Intervals isnât doing any eFTP calculation for durations over 30 minâŚ
That leaves you with nothing.
If you hate short all-out efforts, your best bet is to have the setting at 20 min - 1200sec.
Or you do a real full hour of power and set it manually.
Indeed, thatâs why I am requesting to have intervals.icu make eftp calculations for any duration over 30 min too (if that gives meaningful data )
I second this.
40-70 minutes is enough to use that power as the setting for FTP.
The âeâ in eFTP is estimate.
The short effort modelling method came about to assist people estimate their FTP as it might not always be practical to do a sustained/evenly paced effort every few weeks.
Iâve said this before and itâs the hill I will die on, but FTP in itself is not all that useful a number to base training off. The more I think about it, the more redundant it seems. You can track your daily/weekly/monthly load but other than that I wouldnât pay too much attention to it.
Just my 2 cents. I would pay little attention to FTP. It tells you very little tbh. You canât come up with a single number that covers your whole training range.
Do your easy spins easy and your hard sessions hard and forget about FTP.
Edit - Do 3 min ramps, increasing 20 watts at a time. Start easy. Plot your HR from the 2m45s point in each interval. Youâll see 2 distinct inflections. These are your aerobic and anaerobic thresholds. Customise your zones accordingly.
Or do the Wahoo SufferFest 4DP test where you do a lot of high intensity work prior to a 20 min effort. This âwashes awayâ all anaerobic contribution to your aerobic effort (which normally inflates your FTP) making it your ânakedâ or âsustainableâ aerobic power. Some anaerobically inclined people have âFTPsâ that are sweet too high because their ramp test has been skewed by their anaerobic capabilities. The goal is to set your zones so that when you are doing aerobic work it is purely aerobic and not partially anaerobic.
Additionally, to big-up SufferFest (Neal Henderson) performing their test allows you to determine your sustainable aerobic, maximal aerobic, anaerobic and neuromuscular power. Also the power curves on Intervals.icu are your rider profile and can be used to set your zones. You are your âcurveâ not a single number.
The protocol for the 20-min FTP test includes a 5-min, all out, effort to also take any anaerobic contribution out the number one gets after 20-minutes.
Some other âexpertsâ will argue/debate that the 4DP is too much in one session.
Either way, the number is never static, and which protocol one follows, stick with it for the future too. Then you have something to compare to.
