Edit Plan not working?
Hi - wanting to ‘edit’ a plan in my library to rename it and update the description ahead of sharing, but the OK button remains greyed out even after I make changes?
Tried in Safari on Mac and Edge on PC with same behaviour. Also duplicated plan and tried in case it was related to the original plan already been applied to my calendar, but still no luck :frowning:
Is it just me?
There is a bug that some plans ended up with starting fitness and fatigue of -1. If you make those empty then you will be able to click OK. I will fix this.
That’s worked :slightly_smiling_face:
