Duration issue while connecting powermeter during session
Hello !
I have started below session with Wahoo Kickr connected and then disconnected it during session so that I use my powertap C1.
https://intervals.icu/activities/i373478
You can see around minute 19 cadence is being recorded.
Problem is duration of the workout is 18m52s instead of 90min
thanks !
The velocity stream for that ride stopped after 18 mins when you switched power and that what is used to calc moving time. I have added a fix to consider missing velocity to be moving if more than 20% of the points are missing. Will deploy Wed AM.
thanks David :+1:t3:!
