Duplicate Activity Entires After Importing Strava Data
Hi, I became a supporter yesterday and imported my Strava data following the instructions in the “connection” screen in the settings. According to the Strava import instructions, activities that are already imported from Strava should not be duplicated, but as you can see in the screenshot below all but 1 has been duplicated. These activities aren’t duplicated in Strava. Note in the screenshot showing the duplication, for each activity, there is an entry for “Upload” and “Strava” showing this duplication. This is happening for every activity type.
Are there steps I can take to address this issue? If the answer is just to go through and manually delete each of these duplicated activities that’s also fine, but just wanted to check before doing so.
Screenshot showing duplication of Strava activities:
Strange, this shouldn’t happen.
But now that it did happen, easiest way to correct is using the Activty List View with a ‘source’ filter.
Then select the filtered list and delete with the ‘Edit - Delete’ menu
I got the same problem.
Most of my Virtual Rides became doubled. They were originally linked to Dropbox and Strava. The double activity is a “Ride”, not a “Virtual Ride” like the original activity.
I was using Dropbox as a way of importing original TrainerDay activities. They were correctly automatically linked to Strava activities.
After Strava Import, for each TrainerDay session I have two activities in Intervals.icu, both linked to the same Strava activity, one sourced as Dropbox import (Virtual Ride), the other sourced as “upload” (Ride).
