Drag and drop from Workouts no longer works on mobile after update
Just wanted to report that drag and drop from workout library is no longer working under the new layout on Safari mobile version. The library is now full page rather than a popup which means that there is nowhere to drag to.
Can confirm. Also unable to drag and drop from the Library with the Apple iOS app version of the website. Same thing as Safari. The library takes the whole screen.
Yeah, hopefully @eva can find a better solution for this.
if I want to add a workout to a group. there’s a field that one is supposed to drop the workout on but that’s currently not working.
Thanks for the report!
There is now a new button inside workout edit dialog, “Add to calendar”. On mobile, it is under dodotdot menu.
In addition to that, are you still missing the drag and drop feature? How would you want to organize workouts in different folders with mobile? I’m not sure which one of the features is more used. And one question is that does a new user try to add the workout to calendar by longpressing the workout.
I don’t have the 3 dots ..,
Always check if an update is available through the Settings page if you’re missing brand new features.
I see them :wink:
no, this was not the one.
But I got have them o left down corner after updating on settings
