I’ve created/imported workouts but when I try to download as zwo I get ‘Request failed with status code 500’. I can download fine for erg and mrc, just zwo which is failing.
Tried on two laptops both experienced the same error.
Tx. Can you please msg me the text for the workout that is failing. It could be the specific workout or something in your settings. Should be easy to fix.
I found the issue, it is because ‘type’ is not set. You can create the workout, but Type must be needed for Zwo I assume, hence the 500 error. If I set the ‘type’ in the workout then it downloads fine.
Sorry, I could have done more testing before creating a bug post.
