Skyler
12 October 2024 19:29
1
I tried searching for these on the individual running activity but was not able to find it. These are common running metrics that I’d like to view on a per run basis as well as a general trend basis over many runs.
Am I missing it or does it not exist? If it doesn’t yet exist, would I be possible to add those metrics?
pepe
12 October 2024 20:02
2
There are several custom streams and fields for Garmin or Stryd Vertical Oscilation and/or Ground Contact Time, as well Charts with both.
Skyler
12 October 2024 22:05
3
Thank you @pepe for responding!
I think I must be missing something though because I still don’t see it when I search “Ground Contact time” or “vertical oscillation” in charts.
Would you be able to send a picture of what it is you’re talking about?
pepe
12 October 2024 22:19
4
Garmin Run Dynamics, Stryd Run Dynamics and other charts
Skyler
12 October 2024 22:51
5
Gotcha - thanks!
I turned on Garmin Run Dynamics but nothing shows up interesting. I wonder if it is because I have the FR165
It records those metrics but maybe it doesn’t share them?
You will have to reprocess the FIT file, I believe.
pepe
12 October 2024 23:12
7
1 Select to activate the Custom Streams used in the chart
2 Reprocess all Garmin run activities
pepe
12 October 2024 23:30
8
Do not know if your watch Garmin FR 165 has the Garmin GAP field as FR225 and up.
Skyler
12 October 2024 23:45
9
Perfect, thank you! I had to add the custom stream and then it worked
pepe
12 October 2024 23:46
10
Did you got “Garmin GAP km Pace”?
If you are based in USA, you can use “Garmin GAP mile Pace” Custom Stream instead.
Skyler
13 October 2024 01:00
11
I saw it as an option, but didn’t do anything with it - I’m good with the intervals GAP function
It is unfortunate though that I can’t seem to plot the activities average values (of GCT and VO) on the “Fitness” page
pepe
13 October 2024 01:23
12
For that, in current activity you go to Custom and add an activity field based on that session Fit File Field and choose avg_stance_time (ms).
Name it Garmin Activity AVG GCT
pepe
13 October 2024 01:26
13
Then in Fitness, chart that activity field “Garmin Activity AVG GCT”
pepe
13 October 2024 01:46
14
Creating other sorts of charts, like and Activity Chart, GCT Histogram or Heatmap, is similar.
Skyler
13 October 2024 02:38
15
Wow @pepe incredible - thank you!
Not sure why this is so confusing - I wish it was simpler haha
