I’ve been paying more attention to nutrition on longer rides lately, and it’s surprising how much of a difference it can make when you stay on top of your fueling instead of just eating whenever you remember.
I’m curious how everyone here handles it. Do you use an app to plan and track your carbs, fluids, and electrolytes, or do you just go by experience? Have you found that tracking your nutrition has improved your performance or recovery? I’d love to hear what system works best for you, especially for long training rides and race days.
I go into rides with a specific fueling target in mind. Depending on this, I try to get as close as possible to the total amount for the ride, with the food at hand. That is then distributed over the duration, e.g.: 90g of carbs/h during a 2 hour ride (total of 180g) means a 45g gel at 0:15, 0:45, 1:15 and 1:45. Note that this is a lot easier if you are consuming just 1 type of product
In the past, I experimented with DIY gel in 1 big flask. The conclusion of that was that it was difficult to correctly distribute the intake over the whole ride, leading to issues. With fixed quantity/units, just keep to the schedule.
Eating enough in and out of rides is crucial for both performance and recovery
Fueling by experience alone worked fine for me on 2–3h rides, but the moment I went long — gravel, ultra — “eat when I remember” fell apart completely. Past a certain duration you’re playing catch-up on a deficit you can’t claw back, and that’s usually where the wheels come off.
What actually changed things for me was planning it before the ride instead of reacting during it: a target carb rate per hour (I settle around 60–90g depending on intensity), fluids and sodium scaled to how hot it’s going to be, and then just executing the plan on a timer rather than on hunger. Hunger is a terrible signal on the bike — by the time you feel it, you’re already behind.
Fair disclosure — I build a training app (Summit) that generates a race-day carb/fluid/sodium plan from an event’s duration, intensity and weather, so I’m biased toward the “plan it in advance” camp. But honestly even a note on your phone or a strip of tape on the top tube with your hourly targets gets you 80% of the benefit. The system matters less than having one at all.
Curious what carb rates others are running for long stuff — I still feel like most people (me included, for years) chronically under-fuel.
Thanks for the replies! It’s interesting that you both came to the same conclusion from different experiences: having a plan is much better than relying on hunger. I also like the idea of breaking everything down into hourly targets instead of thinking about the ride as a whole. It seems much easier to stay consistent that way, especially on rides over 3–4 hours.
I’m still experimenting with what works best for me, but these comments definitely reinforce that I should be more intentional about carbs, fluids, and electrolytes instead of just grabbing food whenever I think about it. Hopefully more people will share what they’re using and whether they’ve found a “sweet spot” for carb intake on really long rides.
I use redneck tailwind (table sugar, cheap electrolites, lemon juice, caffeine) that I make 5lbs at the time. Over the last few years and many long rides, I’ve got my nutrition/hydration dialed-in.
I always take a bottle of water on a ride, and anything 90min+ gets carbs. I aim for 60-100g/hr, depending on intensity and duration. I’m also a fan of pb and banana sandwiches added to 3hr+ rides. For century rides, I have found that that the more calories I can take in, the more I like the last few miles.
I use the temp to decide how much water I’m going to need. I get 25 miles/liter of water right now, which is about 90 min. If I use 1/2 cup of my mix, I would get 60-70g/hr. I drink every 5 miles, adjusting how big a gulp by how long the bottle needs to last. I’ve done this for about 40k miles, and it’s nearly automatic.
It’s easy to mix a triple strength bottle, or carry an extra serving of mix in a ziploc bag for long rides. Just dilute/mix when you find water. For a century, I use 2cups of sugar, and a couple of sandwiches and granola bars.
I’m a slow, aging, entirely leisure cyclist. No racing. I find it difficult to eat while riding, especially with real foods like date & oat bars, sandwiches, etc.
My preferred fuel is maltodextrin, which I buy in bulk, about £15 for 5 kg. I put 75g into each 750ml bottle, and that lasts for about an hour and a half of riding, taking 2 or 3 swigs every 20 mins. The drink is not sweet, which makes it easier to consume. Refills can be taken as pre-weighed portions in ziplock bags, or as small bottles containing 100 ml of 75% syrup. The silicone bottles sold for travel shampoo etc are good for this. The syrup is also perfectly good as a home-made gel, and a great deal cheaper than “proper” gels. I add electrolytes for longer rides especially on a hot day.
This system works well for rides up to about 4 hours. Longer than that and I think I’m underfuelling. I add in a cafe stop and eat something full of carbs, and take extra bottles of syrup gel for later in the ride, but my system for late fuelling in longer rides is a bit more chaotic than it should be.
I track calories, both in and out, anyways and use the (imperfect, I know I know) estimation I get from Garmin for similar activities of the past. Then I just prep my food and drink and hit that calorie goal plus whatever my resting base metabolic rate probably is.
I.e. experience from watching these numbers shows that I need around 1000 kcal over BMR for a leisurely day of rock climbing.
For long runs or rides, i.e. consistent endurance, I DIY a glucose-fructose-electrolyte mix and target a certain amount of carbs per hour (basically as much as I can stomach, which is now after some progressive practice, more than I need). I have a 20 minute timer on the watch and gulp whenever it beeps.
All of that may seem complicated but is super simple and time efficient in practice. My Garmin head unit also has drink/food reminders but I never had the interest or need to dig into that.
Just an amateur hobbyist, if you are a pro, ignore.
I’m pretty much in the same boat and have been pleasantly surprised at the results. I don’t think that proper fueling comes “naturally” for most riders. However, it’s the difference between toughing out longer 6- hour rides & finishing with something left in the tank, not to mention aiding recovery. I’ve been trying to consume 75g of carbs per hour usually in a 260z bottle. I did notice that I need to add more water to the mix when it gets hot outside. I’m still dialing in my fuel but what I’m doing now is way better than eating & drinking when I get hungry or thirsty,
I’m a runner and yes I track what I drink/eat during my Long Runs Google Sheet. No other way. I have my prefered items and I just count the total CHO then input run duration and it gives me CHO/hour as I have some targets and improvements over the duration of my Full Marathon prep work. I have ChatGPT to help planning the CHO target intakes week on week and in case of doubts I ask some advice. There are applications available (with paid subscription as this is funded I guess by nutrition brands) that does that however I have my prefered products tried and tested over the years.
Curious to know if any of the previous respondents are women? Only asking as it’s usually the men I ride with whose power tails off dramatically at the end of a longer ride – not women. And I wonder if physiology is part of this, with men burning through glycogen stores more quickly in general.
Also are the previous respondents training seriously for events or racing them? Or just being serious about fuelling because it makes you feel better, ride better, recover faster etc.
I personally do not track my nutrition during rides and go by feel/experience/hunger, but most of my longer rides are low intensity with only a handful of short steep (1-5 min) or longer (10-15 min) shallowish hills.
I’ve only been caught out once recently underestimating my fuelling needs in the Alps but for local stuff around me (mostly flat or short hills, maybe 1000m climbing over 100km) I can manage just fine on my fat stores and eating something solid every hour or so – bananas, energy bars. I hate sticky bottles and frames so only water and electrolytes in my bottles, no carbs. Most of my rides over 3hrs include a cafe stop, so a slice of cake and I usually also pack a toasted thin bagel with a slice of cheese to eat before the cafe.
When I used to race I was much more disciplined with gel flasks and made-up bottles to be handed up but these days things are a lot more relaxed and sedate for me. Or maybe it’s the other way around… I have wondered whether I’m unconsciously going easier because I don’t eat enough on rides.
Any middle aged women want to chime in with their experience?
My training is currently race focussed. For context, my FTP the last few years tends to range from 325-375. I mix all my own from bulk bags.
I usually use a single high-carb bottle (between 300 & 425g) that I’ve planned in advance with a target in mind, plus a soft flask + gels. My tracking could probably be better, but I’m a mathy person and mid-race or mid-training arithmetic is luckily not an obstacle.
As an example, for my season’s A race, projected 4.5-5 hour race (which turned out to be correct), my goal was at least 600g. I carried:
425g in a bottle (250 GLU + 175 FRU),
150g in a soft flask (90 GLU + 60 FRU)
125g of gels (3x25g + 1x50g)
My plan was to finish the bottle in about 3.5 hours, with a caffeine gel at 1hr and another at 3hrs, then goto the soft flask and remaining gels. I didn’t quite stick to the plan, in that I deviated in the order of consumption, but I did stay on top of my “at least 125g/hr”. Around 3.5-4 hours, my stomach let me know it wasn’t entirely thrilled with what I was asking of it, but it was pretty minor.
For non-race long rides, I’ll usually do 400g in a bottle (225GLU + 175FRU), then 100-200g of sucrose syrup in a soft flask.
Not racing, at least no A-races. I just love prepping in general, and managing my body’s needs actively. I had enough oopsies in my life with intuitive eating, with a few really miserable days out in the mountains. I don’t need that anymore. I feel engineering this is too easy not to do it.
Regarding male vs female - I haven’t looked into the science but would be surprised if there were not fundamental differences. That’s certainly true for fat storage, why not for glycogen as well. That said, physics is true for all sexes, so when one gets to the limit of what the body can store, or produce from fat on the fly, fueling is simply necessary. No way around it…
I’ve added fueling and hydration to the AutoMate app. You can setup:
scoop size, then simply measure in scoops
add your favourite foods/gels, and the simply select the quantity
hydration is measured in bidon size, and consumption is measured in 1/4 increments
hydration is guided by sweat rate, so if you know the range, eg. 0.6-1.1 L/h, you can get a suggested hydration quantity.
It supports pre-workout planning and post-ride activity recording in Intervals. Garmin no longer send the data in the fit file, but Automate fills in kcal In and Fluids In fields, without having to mentally work out how much you consume.
Late to this, but on Viking’s hydration question: a rough sweat rate beats any generic number. Weigh yourself nude before and after a 1h ride at ride-like intensity, add what you drank, and the difference in liters is your hourly loss. Typical numbers land somewhere around 0.5-1.5 L/h, and it shifts a lot with heat and intensity, so check it in both cool and hot conditions.
Most people don’t need to replace 100% of that. The ACSM position stand’s aim is to keep body-mass loss under about 2% by drinking to match sweat loss reasonably well, without overdrinking, since hyponatremia is a real risk on very long, slow events.
Sodium varies a lot between individuals (a few hundred mg to over 1,000 mg per liter of sweat). Many commercial mixes sit around 300-700 mg/L. Salty residue on your kit or cramping in the heat is a hint to go higher. Past 2-3 hours, sodium in the bottle with the carbs also helps your gut absorb the fluid.
