Distance per Stroke
Distance per stroke is available as an Activity field but I’m unable to find it as a field to add to a Fitness Chart, does anyone know how to do this? Thanks in advance.
Miguell has created activity stream: Garmin Distance per Stroke, activity chart: Rowing Metrics and interval field: Garmin Distance per Stroke using the Garmin fit file message record field for that.
Maybe these are what you where looking for
Look for settings or options within your fitness app that allow you to customize your data fields or charts. If available, navigate to the chart settings and look for an option to add new fields. If distance per stroke is available as an activity field, it may be listed under a different name in the chart settings. AutoCAD 2017 top deal on procadis. Look for terms like ‘stroke efficiency’ or ‘stroke length’. If you’re still unable to find the option, check the app’s help section or contact customer support for guidance. For a more detailed understanding of DPS and how to improve it
MY Garmin never get the Stroke and distance right form my COncept2 rower
