I’ve been trying to disable intervals auto-updating all my strava activities every time I finish a workout with adding the weather to the description but have had no luck, it seems quite confusing where the weather settings are. What is the proper way to disable the weather in strava descriptions?
Open an activity that is on Strava, then follow what’s in this post
Weather settings are under Options > Edit Layout, then click the gear icon on the weather. This allows you to add/change the location only, but not what you’re looking for.
Weather on the activity/workout level, is for premium users, so you might not see the solution that @MedTechCD shared.
