HI! as you can see from my strava training I did a lot of laps. Why do I only see 3 on intervals? Thank you
aweryc
2
You can press Option - Use Laps and you will see like in Strava
Could be the problem with the Strava Privacy circle which messes up the laps.
isn’t it already active??
It is, I see that in the screenshot you added. That’s why the Strava Privacy circle could be the culprit.
but shouldn’t you get them from garmin anyway?
Do you sync from both Garmin and Strava? If so, Intervals will take the Garmin FIT file.
Check the source of your file:
And check the second checkbox to. They might be logged as recovery intervals:
