I activated the Suunto connection in the settings with health data download enabled.
On Intervals, data appears, but when I open the health data for the corresponding day in the activities section, no detailed data is shown.
SpO2 is not selected in the fields, even though data is available.
Thank you for your feedback.
I may not fully understand your question but I think you mean this:
- If you want to enter Wellness data, you do that through the Wellness dialog and you can define which fields are visible in that dialog by selecting them.
- The wellness data that you want to see in the calendar (for each day), can be configured by going to Options (on the calendar page), then Wellness and select the list.
Depending on source and configuration, you may have more then one field option for several metrics. Example for HR rest below
