Custom fittness diagram filter not working
I have made a custom diagram an added as filter , running, trail-running , walking but in the diagram also the bike trainings are shown:
Please show the script for the ‘max VAM’ custom activity fields, and also the Description tab.
My first intuition is that this is happening when you have both bike and run on the same day. Custom activity fields are aggregated per day and not per activity type.
The solution might be to set a condition in the script of the Custom field to exclude bike activities.
no i have added the activity type but still it shows the bike trainings:
I have changes it from 14 Days intervall to unchanged to show all data an i still see the bike training on that day:
Or do i have do delete the data in the custom variable because now the script returns 0 for that training? If it is that way - how to make it ?
For custom activity fields to update , you need to reprocess. Or, if it’s only a couple activities, open the config dialog and run the script from there and confirm by OK.
thank you this was the solution so the activity filter on the diagram is useless,
No, the filter works perfectly fine for standard fields. Custom fields are a step further and then it depends on what the field is calculating and how it is aggregated. Not always obvious…
