CSV export shows distance in meters
When exporting to CSV the distance exports as meters whereas the units I’m using are actually in miles
Intervals uses the metric system for all units. Conversion to Imperial is only done on the GUI. When adressing csv and API content, it will all be metric.
Well that’s a bit naff, if they are going to do that I’d have thought the export for distance would be in Kilometers
Then some people would be complaining about 0.025km for swim lengths.
So have a selection if you want distance in meters or kilometers, both are metric measures of distance
No, a csv export is meant to be used in a spreadsheet for further customizing. Simply do the conversion to what you want in your spreadsheet. It´s one formula…
Hear hear
Shouldn’t be necessary, you select the units in the app, it should follow what you specify
