Create custom data fields for stryd
Hello! Can I import fit files from stryd Powercenter manually and import custom fields from stryd (such as form power, air power, leg spring stiffness, ground contact time…)? I have noticed that there have similar fields created by users for Garmin devices, yet I am unfamiliar with JavaScript programming.
Sure you can. Just use the tool fitfileviewer to import your FIT file to see what are the fields you want.
Thanks, I will give it a try.
Done that, but I am missing something as in no way I have been able to add Stryd fields e.g. form power to the charts where the FIT file contains its data
Has anyone been successful here?
