It’s there a way to convert workouts made in power to hr ?
Add “HR” after the %, and then make sure your % of LTHR or Max is correct.
Just ignore the black coloured graph.as I converted a Power workout to HR.
But if do that when the power its 110% will be 10% more of my hr right?
Yes, which is why I mentioned to change your HR to the correct value (% of LTHR or maxHR).
Ok thanks I understand now
You can also use the zone code, like this example, but you need to understand the difference between power and heart, as there isn’t a 1:1 relationship between power and HR; and there is the lagging nature of HR.
Power
6x
- 30s Z5
- 30s Z1
Heart Rate
6x
- 30s Z5
- 30s Z1
