Apparently, it is not possible to update the activity streams currently. Being able to do that would enable a calculation of virtual power for runners based on pace ![]()
I am going to add computed activity streams soon. Busy with computed wellness fields now.
Just trying out this new feature by looking at some of the examples ppl has shared.
When I export the FIT file, it doesnāt seems to have the āWork above FTPā Field. Has it been implemented or Iām looking at the wrong place?
(I tried using the FitSDK to do the convert to csv)
Can you please check on fitfileviewer.com. Thats what I used to test.
using FitFileViewer.com and I donāt really see any indication of it.
Hereās a screenshot on the activity page: The last number is the work>FTP
Then I go to intervalData and click the Export FIT and open it in FitFileViewer.com. I donāt see any developer fields inside.
Should I be using the āFit Fileā option or the āOriginal Fit Fileā option?
Only these 2 are available.
When I use the Original Fit File, I can see my Stryd Developer data inside, but when I use the āFit Fileā these are stripped out. (Intervals.icu)
Aha. I was thinking of custom activity fields. I have just implemented support for exporting interval fields in the lap records.
I see it now.. sorry about that..
TBH, i didnāt know/understand the difference between this and the Custom Activity Fields. (I was looking at this page Custom activity fields - #4 by Collin_Drake but wasnāt able to locate any fields to be used similar to the pic in that thread, but did find the Interval fields so I played w/ that instead)
NOw I found it..
Tx⦠all sorted.
The naming of the buttons is unfortunate ⦠but I didnāt want to rename āFieldsā to avoid confusing longtime users.
I got a little confused about all that to, so made a quick mental matrix: (needs to be updated for plots but havenāt found out yet)
Custom Field Type Create/Config Numeric Display 1 NumericDisplay 2 Plot 1 Plot 2
Custom Activity Field Activity Page>Custom Activity Page Summary Activities List View Column Fitness Compare
Custom Interval Field Activity Page>Fields Activity Interval/Selection Summary Activity Interval Data Column TBD
Custom Wellness Field Activities>Add Entry>Wellness>Fields Activities>Wellness Fitness Compare
@david, is there any limit for code lines number? I am thinking in preparing my own library of functions for whatever math tools that could be useful when I create any custom fields (or better, when this stuff is extendend to charts).
Nice! This is great. Iāve added some really valuable fields.
There is no line limit but scripts are killed if they take too long to complete and parsing a lot of functions might take a while. Also you will need to copy and paste your functions into each script. I might need to add a library concept at some point to solve that.
Brilliant!!!
Funny timing. I have been thinking about this; if Intervals could he used to create custom queries. Eg, how many Saturdays did I do a bike workout in 2022. What percentage of workouts were longer than 4 hours etc.
This is an exciting new development.
Thank you
Hello, everyone,
I wanted to thank David before my first question for this great program!
I would like to display my performance over 20 minutes in the computed activity fields. Unfortunately, I have no idea about Java. Maybe something like this has already been programmed for itself and would share it with me?
Thanks!!
Tx. Do you mean your highest power for 20 minutes for the activity?
Hello David,
Thanks for the quick help!
Yes, that is exactly what I mean.
Thank you very much
Is there a way to use these custom field scripts to calculate values on a per interval basis, or only for the whole workout?
Yes there is..
Check out my original confusion where it was at the interval level isntead of every second.
Unfortunately the power, HR and pace curves are not available yet. The internal data structures for those are a bit messy. I need to do some work to wrap them in something user friendly and then I will make them available to scripts.
Understood!
Many thanks for your effort.
