I just discovered the ability to add ones own charts on the fitness page. So I added sleep hours to keep track of my sleep.
What I’m missing is an option to color those bars when they are below or above a threshold. Like: default bar color: blue, < 6h: red, >= 8h: green.
Check the guide pages on fitness.
It adresses that functionality.
The Fitness page. [Fitness page icon]
The Fitness page is without a doubt one of the most important pages because it gives you an immediate overview of the result from everything you’ve done in the past and, everything you’ve planned for the future.
The Fitness and Form charts are the heart of the page and if you come from another software suite, you may know them as the PMC (Performance Management Chart). The terms Fitness/Fatigue/Form are used iso of the trademarked CTL/ATL/TSB ™. The idea a…
More specifically here: this allows to set background colors per zone
You can also add background colors to visualize zones by clicking on “Add Item”, setting the Y-values and defining a background color. The label for the zone can also be set and will be displayed on the chart. If you just want a line to indicate a certain level, set both Y values to the same number and a line in the selected color will be shown.
thanks for the hint, I missed that one.
So I’ve managed to color the background in the upper/lower part of the bar chart.
but currently there is no way to instead of coloring the background, change the color of the whole bar? so a green bar when >=8h, a blue bar between 6h and 8h and a red bar below 6h?
Don´t think that´s possible
david
18 October 2022 19:25
5
Not at the moment. Probably at some point in the future …
