Color Coding on Power tab table
I realize I’m probably the exception here, but I added a lot of “best time” periods to the table on the Power tab. Whereas the default is I think 1s, 15s, 5m, and 20m, I have around 25 different lines. I realize that you can compare via the graph on the left, but I like to see the numbers both on the graph and the table. Problem is, if I am trying to see which time period I had my best effort in, it takes a bit of effort.
To demonstrate this, I would expect some kind of indication (bolding, coloring) on the lines that I have circled in the image, showing that the best effort occurred in that period.
I like that idea. Make the all time bests stand-out in some way.
I have had a shot at this. It’s hard to make it stand out but not look horrible. Bold already taken. Background colour interferes with hover. Border looks horrible. There is a css class “best” on the appropriate td’s if anyone wants to try improve it :slight_smile:
You’re awesome David! This is great. Minor feedback but red is kind of aggressive to look at, maybe a more calm color like navy blue or dark green, or even just a different shade of black
Also just FYI, the w/kg doesn’t color properly in some cases.
Watts and watts/kg are highlighted separately. For your 3m row:
The highest w/kg is the last column.
I have swapped it to blue.
Makes sense! This looks amazing, thanks for all your great work and timely responses!
