Change Power Zones for one ride?
Hi, my Garmin 1030 is set to ‘indoor’ Wattbike Atom Power Zones, I’ve just done an ‘outdoor’ 2hr ride with Power meter.
There is a huge discrepency from indoor to outdoor power ( in the region 30 - 40 w) this has skewed my stats, is there a way of manually altering the odd ride to compensate for the differences?
Or any suggestions other than altering my zones in the Garmin before every outdoor ride?
Great product… is it easy to contribute towards the cost?
New to this forum, did a quick search of the topic, but couldn’t find any answer.
Thank You. G
The “Fix data” functionality provides a way to correct the power. Corrected power = x *Power+ y.
If you know the difference is +/- 35w constant, just apply the offset factor.
superb, thanks very much
apologies, I have done as suggested, pressed ok, but nothing changes? am I missing something? I’ve ticked the fix power button too.
Sorted it… nice one
Are you sure? Just did this on my own data and it worked flawlessly. First check your Avg Power in the header.
Tick Fix Power, leave scale on 1 and set offset to e.g. -35W. Click ok and check Avg Power again. It should be 35W lower, and I suppose Time in Zone changes accordingly.
