Change max heartrate
hi,
i increased my max heartrate in the heartrate zones table, selected the option to backdate the change to previous rides, clicked recalculate.
this worked fine for many things but my custom graph of max heartrate in the fitness page is still clipped at the old rate.
maybe i misunderstood or its finger trouble, but maybe its a bug…
-Steve
The UX in that HR zones dialog needs a bit of work. If you enter a new max HR on the grid and then click “Recalculate” it will reset it based on whatever you have entered for threshold HR. So check to see if the max HR you entered has been saved.
Also it might take several minutes to update you old activities.
the change in the heartrate zones is remembered correctly.
i changed my heartrate 24 hours ago, and tried. hitting reload in an attempt to get intervals to re-ingest my data from strava.
however my maximum heartrate shown in the maxheartrate graph is still clipped at the old number.
it is not a major issue, but i think it is a bug.
-Steve
I have seen this behaviour as well.
I have added this to the bug list (only 8 items, will get to them when Strava separation is done).
