Bulk Edit HR data?
Did a ride last night, but as soon as I started, I realized my Tickr was reporting really odd HR data - in the 70-100 range for efforts that would easily be in the 130 - 170 bpm range. I also track my workouts on my Fitbit, so the HR data there looks more reasonable.
In the activity, I have already set it to “ignore HR data”, but I was wondering if there was anyway to import the FitBit data and use a time match to swap out the HR data from the Strava file? I know I can do it manually per data point, but not really an ideal solution. I know the answer is probably no, but figured I would at least check!
Not at the moment. What you can do is Actions → Fix data and set sections of the ride to a specific HR (use scale=0 and offset=bpm you want).
Thanks! I did consider this, but since there is not a consistent offset across the whole ride, I would really just be guessing, so I think I will just stick with “Ignore HR” for this ride and try to figure out what is up with my HRM!
