Now that you’ve added power for rowing, I wanted to re-analyze my previous activities back as far as I thought my estimated FTP applied. When I did that, it did the analysis in descending chronological order from the activities table (starting from today and going backwards), which is the standard sort order for the table, meaning that every single rowing activity was my PB. I had to re-analyze a second time to get the PBs to match properly. The simple solution is to always do batches in ascending chronological order.
I will update that as you suggest. Tx. You can also use the “Update activities” button in the “Rowing” section in settings to reprocess all of them. This does do it oldest first.
