Hello ,
I created custom fields for each activity as pictured and then manually fill them in at the end of each workout when I upload to intervals.icu.
From activity list I select “reprocess original file ( non Strava )” and in all my fields emptied , all notes were deleted.
It’s normal ?
I noticed another thing : by entering in the activity my field recovered from the .fit file .
if I reprocess the original file from the activity screen ( Actions → reprocess file ) the data ( and also others added ) do not update.
The only way to update them is to go back to the activity list , select them all and reprocess the files.
But in this you empty all the values entered in the previously created personal fields
Hmm … the re-process file option wipes everything out by design (clean slate). But maybe I should keep custom activity fields without scripts or links to record fields? These can be manually captured but could also be updated by other fields with scripts. So that will break the “clean slate” thing a bit.
I wasn’t able to reproduce the “Avg L Pedal Smoothness” not updating issue. I manually edited it to 30, did re-process file and it reverted to 24 as expected.
Thanks @david ,
In my opinion , reprocessing should keep the manual fields …if I enter my notes throughout all the year and in December for whatever reason I need to reprocess the activities , I lose all my notes.
It would not make sense at this point for me to enter my notes in the workouts.
Same problem with activity names…if I reprocess the file the name given previously disappears and is overwritten by the tags.
Or , in your opinion , can I solve this problems in another way to mantain my notes ?
Sorry @david ,
it would be better to also keep the tags in the name of the activity.
I also encounter the previous problem when adding tags to the activity…When I reprocess the activity, the tags disappear
