Once you bring calories from Strava would be great to also bring work once ICU doesn’t make that figure for non power meter activities.
Thank you,
Thank you,
Hmm if they are deriving that from the estimated power it is likely very bogus. You could just use the calories number (at 23% or so efficiency kJ of work is approximately the same as Kilocalories or Calories with big C) … though that is calculated by your device so you would need to find out how they do that.
Right, but as with Calories ( each device/app tell us one) would be easier to have that number ready to make charts and totals.
Just put the same warning that the numbers come from Strava…
Tks
For some reason Kcal figures doesn’t apear on my mobile IOS Chrome.
Also I was curious about the efficiency of 21% to work mentioned before because kcal and Work show identical on the desktop version.
Tks
I assuming you mean “work does not appear on mobile” … you need to click “Options” and choose “Show work”.
Intervals.icu uses the kCal from Strava which uses whatever the device says. So it is quite likely whatever did the recording is assuming kJ = kcal.
Tks.
The device is a Garmin Fenix 5x.
It was marked.
Don’t know what was happening but now is showing.
Regards.
